paul b b
hello chaps,
i am working on a barn and stables, they have put 16mm swa in to the barn and taken 1 from the barn to the stables, whats the best way of joining the swa? i was hoping not to use the cu in the bard as i didnot want to trip the rcd in the barn from the stable (if you can understand that)
can i put a 3pole henly in a ip rated box?
or should i get a 3 way cu
both buildings will have a garage unit with rcd.
it will be fed from a 100ma s type as its a tt
thanks
thanks
