+1i bought one of these the other week as i had a far bit of 6mm swa to work onhttp://www.tlc-direct.co.uk/Products/KTWSBR28.html?utm_source=overture&OVRAW=kewtech%20swa%20stripper&OVKEY=swa%20stripper&OVMTC=advanced&OVADID=19813570031&OVKWID=152235814031&OVCAMPGID=616310031&OVADGRPID=9974044419
does the job
Then you could not have been using it right as its very quick.I partially cut through with the hack saw, then without stripping the outer sheath, I bend the cable back and forth untill the wire breaks.I've tried the tool, and found it takes longer, and I wonder how long the blade will last.
I bought one of these myself and found it useful when you get used to it . I still like using a junior hacksaw though .i bought one of these the other week as i had a far bit of 6mm swa to work onhttp://www.tlc-direct.co.uk/Products/KTWSBR28.html?utm_source=overture&OVRAW=kewtech%20swa%20stripper&OVKEY=swa%20stripper&OVMTC=advanced&OVADID=19813570031&OVKWID=152235814031&OVCAMPGID=616310031&OVADGRPID=9974044419
does the job
Me too. Creates a good start - but still felt I needed to go over th cut with a hacksaw to get a clean break on the sheath. Overall though it has saved a lot of time.i bought one of these the other week as i had a far bit of 6mm swa to work onhttp://www.tlc-direct.co.uk/Products/KTWSBR28.html?utm_source=overture&OVRAW=kewtech%20swa%20stripper&OVKEY=swa%20stripper&OVMTC=advanced&OVADID=19813570031&OVKWID=152235814031&OVCAMPGID=616310031&OVADGRPID=9974044419
does the job
