Firstly I apologise for the photos, they are a mix and match but hopefully go someway to show how (I) to terminate swa.
As said after terminating one end & mounting enclosure, clip swa in position upto a short distance from the other termination point.
http://i83.photobucket.com/albums/j293/gazjothomas/2-1.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/4-1.jpg
Mount enclosure & fit
Put pvc gland cover on first (tip1: reverse it & push on to swa this gives a nice indication where to cut carrot so it isnt loose on swa, remove & refit correct way round)
Slide rest of gland onto swa.
Hold swa up to termination point & mark where you will be scoring the armour for connection to gland, ensuring the core tails are long enough to reach their termination point (tip2 for begginers: wrap one turn of insulating tape to lower side of score mark, use hack saw to continue scoring armour using tape as a guide...leave tape in place for now)
http://i83.photobucket.com/albums/j293/gazjothomas/swa1-1.jpg
Remove excess outer sheath by using knife, hold blade at a 45degree across the swa slicing away from you, the remainder of sheath will pull off.
Now untwist armour & if you have gone deep enough with the hacksaw score, you'll be able to bend back and forth a few cores of armour at the same time untill they fall off. remove all armour cores this way.
http://i83.photobucket.com/albums/j293/gazjothomas/swa2.jpg
Now you should have the inner sheath on show, no armour & a wrap of insulating tape around the outer pvc sheath.
http://i83.photobucket.com/albums/j293/gazjothomas/swa3.jpg
Remove outer sheath to bare enough armour to gland.
(Tip3 for those that cant measure: using your knife score the outer pvc sheath around the lower edge of the insulating tape wrap, this will be just the right amount of armour to gland)
http://i83.photobucket.com/albums/j293/gazjothomas/swa4.jpg
Hold the inner sheath rotate it to fan the armour.
http://i83.photobucket.com/albums/j293/gazjothomas/swa5.jpg
remove inner sheath, but leave enough so it just peeps over the to of gland when put into enclosure
http://i83.photobucket.com/albums/j293/gazjothomas/16mmswasubmain.jpg
Offer swa up into enclosure run olive gland nut upto armour & tighten, run up & tighten cw nut cover with boot (picture just shows olive & bits no enclosure)
http://i83.photobucket.com/albums/j293/gazjothomas/swa6.jpg
Dont forget the banjo with earth lead + nut/bolt or use a Piranha
