You would need to feed it via a fused connection unit, similar to the above, you could use a switched version to give you isolation in case the outside light goes faulty and keeps tripping the RCD!
Please ensure that you do this safely, ensure that the power is off, and that all connections are sound, and that the cable is not damaged when installed.
An electrician doing this work would also test the circuit for safety, I suspect that you don't have the equipment to do the tests as required by BS7671?
