Testing a fan
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Been having probs with a fan (manrose shower kit). As soon as it was connected it took out the 5A Rewirable fuse. I have tested the resistance of the fan and its 517 ohms. Is there any other way I can test this fan. I could wire it up with a plug with 3a fuse I suppose. If its not the fan itself must be the PCB.
Any ideas on ways it can be tested apart from the bang test lol.
Cheers
99.99999999999999999999999% its a knackerd PCB....
loads & loads of them use the same timer circuit PCB...
If the existing fan is all brand new get a warranty replacement..
If its been in there for more than 12 months..
buy one of these...
Manrose Axial 20W Bathroom Fan | Screwfix.com
swap the PCB out of it..
Then either keep the new fan for use as non-timer operation
or take the new one back as faulty!
IIRC there's a big fat resistor on the timer PCb that can often burnout..
anyway the PCBs have a regular tendency to go faulty...
:coffee :Salute
Hi,Been having probs with a fan (manrose shower kit). As soon as it was connected it took out the 5A Rewirable fuse. I have tested the resistance of the fan and its 517 ohms. Is there any other way I can test this fan. I could wire it up with a plug with 3a fuse I suppose. If its not the fan itself must be the PCB.
Cheers
517 ohms, that's a high reading for a fan winding, the insulation might be breaking down under load and shorting.
Thanks for the replies guys. The measurement was taken from opposite end of pcb from incoming cable so it was measurement of fan windings only.
Andy I did swap it for a 6a bsen 60898 mcb plugin mcb. Cost
