Did it have surge protection? Every time I've tested a property with surge protection extension leads they always show 0.3meg to earth!Had an odd one today on a PIR, Could not disconnect an extension lead with Neon from a bedroom socket as a Water bed was tight up to it!Tried a L+N to Earth at 250 Volts got >9.99 M ohms, so went for 500 Volt test and got 0.33 M ohms
Any one got any ideas?
Cut the extension lead wire then rewire it after? That's what I did when I had one going to a socket behind a bookcase that would take a week to moveHad an odd one today on a PIR, Could not disconnect an extension lead with Neon from a bedroom socket as a Water bed was tight up to it!Tried a L+N to Earth at 250 Volts got >9.99 M ohms, so went for 500 Volt test and got 0.33 M ohms
Quite...Did it have surge protection? Every time I've tested a property with surge protection extension leads they always show 0.3meg to earth!
