Blue Fox
- Dec 12, 2008
- 351
- 1
Hello all,
When doing a job like a c/u change when you test all the circuits do you remove all the plug socket faces and check behind them or do you just test from the front? The reason I ask is I've been removing every socket and lightswitch and ceiling rose cover and testing but the time this takes me is far longer than other people have quoted for jobs that I've seen mentioned on here before. I've been doing this for every job for example fitted a new socket in a kitchen and went round removing ecery socket cover. Am I doing a bit of over kill here or am I just slow?? Also if this isn't done on an EIC or minor works is it done on a periodic normally?
