Plw
Hi there,
I understand that a cpc continuity test is used to make sure that the wires are continuous and to make sure there is no high resistance within the circuit. I know that there are two different methods of testing, method 1 and method 2-long lead method.
I just wondered whether the method (1 or 2) you use is dependent upon the type of circuit (e.g. radial, ring final, lighting etc.) you are testing on, or if you can use either method for each type of circuit.
Thanks.
Thanks.
