Ive read the sticky above, and hav a few questions to ask please.
Installation:
-Is the outdoor socket on its own circuit? (supplied via a rcbo)
-How is the commando socket wired?
-Do you bond any trunking? or do you just run a Gas and Earth bond in
Testing:
When doing Insulation resistance:
- do you connect your supply and load togther using connectors, at the DOL starter, leave the neutral in the block and the earth in the block, and then disconnect and the motor?
-do you do your safe isloation on your job, then cpc test's, IR's, then juice up and do your Ze and Pfc?
i would also LOCE IT if anyone had the time to do a brief step by step of each circuit, from leaving the D.B
THANK YOU'S ALL VERY MUCH IN ADVANCE, HOPE I GET SOME REPLIES, I WILL APPRECIATE IT! THANK YOU.
