Times fused spur
Blue Fox
Dec 12, 2008
351
Hello all,
I want to fit a couple of small panel heaters off fused spurs for a caravan, but I want to be able to set them on timers so they come on and off by themselves, anyone got any ideas can't find anything suitable. I know I could fit a timer into cu but trying to avoid a new circuit as heaters are only small and don't really want the plug in timers.
That is what I thought, built in 24hr timers and thermostats I recall seeing.
The only disadvantage of one of those is fitting them in the normal heater spur position....
It could be a bit low down on the wall making it a bit of a bum to read the display whist setting it up..! :|
It may be an easier operation if the spur is mounted near the CU and divert the outgoing circuit through it there...
Thats assuming the CU is in a more reasonable position of course!Blushing
