hi can you chaps can you just explain something to me that confused me this week, after installing a new power circuit in a block of flats i was told to do a R1+R2 and then a ze i was unable to disconnect the earthing conductor as the consumer could not be isolated. firstly is this exceptable to work in a live consumer unit taken a ze reading. secondly the reading was 0.47ohms for ze yet there was a large sticker on the giant lucy enclosure stating p.m.e. the guy i was working for said that it must be tns. as we got a similar read in the other blocks of flats. the flats are about 3 years old and i thought tncs/pme was installed in most new properties. would the correct procedure be to contact the supplier to confirm.
cheers
cheers
