depending on the make of the cu you can get kits where you change out the guts of the board done a few of these on council properties think i got mine from bemco or wfNo sadly the Estate Agent who was giving me acccess to the property did not want me to take any pictures of the property. I'm not sure why a consumer unit should have worried him but it did
you should get the DNO to change the earth onto their clamp. If you DIY, make sure its the correct clamp to start with and the cable is in reasonable condition.Assuming that I get the job can I just change the earth cable for 16mm pukka stuff and connect it to the power company cable myself or does the power company have to get involved?
If that's three strands of what looks like steel wire, then you are looking at the normal suppliers earth for TN-s. I would suggest re-terminating close to clamp with an MET and connect your 16mm to that. If you are totally un-happy with the size of wire contact DNO to come and inspect. (even better photo and post on this site when agent isn't looking)The earth type looks like TN-S. There is something that looks as if it is a main earth going from the area where the fuses are to the clamp on the power company cable. It is a rather pathetic three strands of metal loosely entwined together and not covered by any sleeving.
had too many Guiness DrinkGuiness DrinkGuiness Drink already?!Sure Andy's post wasn't there 2 minutes ago:coat
Nah, haven't been to the shop yethad too many Guiness DrinkGuiness DrinkGuiness Drink already?!
better get used to it then!But I have never seen anything quite so pathetic before.
Unless its needs replaced for safety reasons, chances are you will be charged for it. at least it is round here (NEDL)I would phone the utilities company and ask for a cut out change, this is free of charge and a rolling works ticket in my area.
