Trace heating
Andy™
©Resident Geordie™
Jan 1, 2009
30,739
1,459
S. Tyneside
need to get some trace heating on some pipes before it gets cold again
there is one run approx 15mtr long, with branches from it, each about 4mtr long
been looking at something like this
looks simple enough to cut to length / branch off (although ill probably run a 230v to each branch and keep the long run uncut)
is this the way to go, or any other alternative i should be looking at?
I think you'd be OK with that stuff Andy, just follow manufacterer's instructions .
I think they're all much the same TBH.
There used to be some you were not to cut , just check that.
Still not done that one Jono!
All the lagging & heating kit is on the shelf & paid for, no PO number yet, nor chance to do it!!!
[SIZE=10.5pt]Possibly the most common use of trace heating is for pipework frost protection. Self-regulating heating cable rated at 10 watts per metre will be suitable for pipe sizes 2" and below[/SIZE]
