Tripping RCD on Night Storage
ITS
Oct 3, 2008
39
I've just been called to a customer who can't reset his RCD on the night storage CU. When I had a look, it would only reset if the main switch in the main board was closed. As soon as I opened the main switch on the main board then the RCD on the Econ 7 CU tripped.
This is a fault that has just appeared. Investigating further - it is the neutral that trips it (but only when the main switch on the main board is closed). Any ideas?
+1 to the above. You won't find the fault without some testing.
Because circuits on one CU are affecting what happens on another, It must be the circuits linked in some unintentional way so shouls be easy to find.
