Hi all
I was asked to look into an RCD tripping on a dual rcd board.
When carrying out an RCD test I get TRP come up on the megger when I am plugged into the ring circuit.
This happens when the socket mcb is on and the boiler mcb is on.
If I disconnect the the supply to boiler spur and reenergise, plug the megger back into same socket I get my rcd readings (all readings within limits).
Am I right in thinking that it must be something to do with the boiler that’s causing the intermittent tripping of the rcd?
Thanks in advance
Thanks in advance
