TRVs
Rev,
Rad valves will almost certainly be 1/2" BSP if they are 15mm entry the sizes are about the same, in fact IIRC the thread used on a 15mm compression nut is 1/2" BSPP.
I am unloading plumbing stuff in the morning, I'll try to remember to check!
Metric pipes are characterised & measured by OD.
Imperial pipe sizes are characterised & measured by bore.
Well at least in the UK they are!
Metric ones are OD globally, but not sure about the global imperial pipe standards, though NPT is bore.
Rev,
Some old fittings had a 1/2" BSP M for the rad end, and a 3/4" BSP loose nut for the valve IIRC.
Don't think I have any of these still kicking around.
