J
Jammin
Guest
Hey guys need a bit of advise as a newly qualified spark. I've started installing solar pv systems in Northern Ireland and yesterday went to look at a potential job. Its a TT system with no visible Earth the main incoming supply is in one of the out buildings I looked everywhere nothing in any of the consumer units no bonding etc its very old! never come across this before, so I know I'll have to put an earth rod in but my question is, if I run a new cable from the inverter in one of the out buildings straight to a new garage board by the main meter bypassing all the existing wiring so just my installation Is earthed, and advise the customer to get remedial work done on all his existing wiring is that ok? or do I have to sort it so everything is up to regs in which case its not worth doing the job.
Sorry if I'm a bit thick but I'm new to all this so any advise would be much appreciated.
