I get to do a lot of these, so...
I use 50x25 trunking so only need to chase in around 30mm+, this is big enough to get a SCART though if vertical, although I usually put the SCART in before I cap and plaster. However mostly now I just put in 2xHDMI, 2 Coax, and 1x CAT5e and can be done after plaster has been finished (so cables keep clean)
I top and tail with a 35mm back box cut to take the trunking, and use a data grid plate on the top neat but hidden anyway
An example of one I did a while back
http://i645.photobucket.com/albums/uu178/robojin/Wallwithtrunking.jpg
I agree with the comments on 230v by Lurch, if customer is happy to pay I'll chase in a single socket (as per BRB, with RCD etc) and some large sets are hard wired Philips,Toshiba come to mind, otherwise just an extra long IEC lead or figure 8 style
Also handy to have a few right angle HDMI connectors and RA Coax, useful for those customers who must have the TV flat against the wall an you only have 30mm clearance
Found a SCART to HDMI (Upscaleing, with audio over SCART) if you ever need one e.g. you put HDMI in only to have the customer decide that they do want SCART after you have installed trunking with 3 turns headbang , but does cost
