TheFamousForry
Good day, does anyone know if the Hemisphere apartments in Edgbaston Birmingham has a wet or dry underfloor heating system , only all rooms are reportedly not heating so not likely to be the Devireg 550 thermostats that control each individual room/area. Any ideas on what else I may best look at when I get there. is it likely to be the pump,on a wet system for example? Thank you all regards David
The floors are all wood.
