Never installed underfloor heating, but was asked to look at a system that had been part installed by the homeowner.
The matting has been laid and tiled over.
Both connections are to short to reach FCU
One cable is a black two core cable, which i presume is power
The other is a blue single core cable which appears to have a copper core and a copper shield. I thought this must be the temp probe.
However the home owner then brought out the temperature probe which he did not bury under the floor.
He plans to try to push it a couple of cm under the tiles.
So thats three cables!
So I am unsure what the blue cable will be, any ideas
Is it possible / advisable to join cables
Is not using a temp probe and putting it on a timer a complete no no
I am very reluctant to touch any of this, but any guidance would be great, so I can better advise the customer.
