Unknown device on the back of a garage.
eckcop
Jan 11, 2025
Does anyone know what this thing is? About 8ft off the ground, looking out over a field. Seems to be connected to the mains.
Wot Andy said....
Photocell...
Basically it turns lights on when it gets dark...
Then off when it gets light!
e.g.
https://www.toolstation.com/electronic-ip44-photocell-kit/p62528
Oh.. and I forgot to say.. Welcome to the magical electrical forumbulator...
Where you can expect to find a wealth of knowledge and guidance... for all sorts of electrical related questions..
But also hard basic facts when it is quite obvious that someone with insufficient knowledge is trying to wire up a potentially dangerous alteration/addition....
As none of us would like to assist in the creation of any potentially dangerous wiring, that could injure or kill someone before any protective devices can disconnect the source of electrical energy!!
Useful tip #103 for electricians. Keep a black bin bag in your van. Perfect to cover such sensor so it thinks it is dark and all the outside lights should come on and you can go and check them.
If you need to replace one, they unplug like a bayonet fitting so no witing needed just unplug the old one, plug in the new one.
Thanks for the replies. Knowing what it is now I can remove it. The outside lights it connects to don't work and this has been the case for many years. I am more intent on rendering the wall behind it (when the weather gets better) than on fixing / replacing the outside lights. These are further down the to do list.
I have seen these sensors other places, over the course of many years, and never stopped to wonder what they actually do. A shameful lack of curiosity.
Be very careful when disconnecting it as I would assume that its 3 core flex going into it and what should be the earth cable will more than likely be the switched live !
