Doc Hudson
- Oct 21, 2008
- 5,619
- 230
"It only points out how few domestic properties you've seen". An absolutely pointless and patronising comment. I had better return my 17 properties as clearly I don't have a clue what I'm doing....
It is NOT a standard (as in typical style of) residential board. And other electricians have told me so.
Everyone else, thanks for info. Should I sort the corrosion before booking EICR?
The comment is neither patronising nor pointless. The first sentence was both for your benefit and for any others reading this thread. To make it clear that there is 'No such thing as a standard consumer unit'. As I would hate to think anyone new to the trade is always going to be expecting a B&Q or Wickes off-the-shelf enclosure if they are doing a domestic alteration. Irrespective of what any other "electricians" have told you, anyone who says otherwise probably hasn't been in the trade for very long, or has not done much domestic work.
To clarify a bit, it was not uncommon at all for "acquired" materials to drift from work to an individuals home project. Historically when this country had a thriving manufacturing industry, there was a vast army of industrial maintenance electricians who would 'borrow' a more commercial looking enclosure to fit at home when doing their electrical alterations. Although in a larger enclosure they would typically have correctly rated protective devices for each circuit. (In a similar vein it was not uncommon for those working in the motor trade to bring parts home to do their car maintenance and servicing work). You also find jobs installed by the builder or DIY which have a smaller enclosure, but half of the circuits have inappropriate or incorrectly rated protective devices because those were the fuses that came in the fully equipped off the shelf board, and they have no idea about correct circuit design. (who else has found the 2.5mm ring circuit put on a 40A MCB, because that's what the board came with, and the customer didn't have an electric shower?). Then there are the proper electricians, small businesses or larger organisations, who as well as designing bespoke per the job, may also have a surplus stock enclosure left over from a cancelled contract, or just part of a bulk-buy discount, so they decide to use a more robust enclosure in that domestic rewire job to get it off their stock.
My earlier comments still stand, and the second sentence gave my recommended course of action:
Nothing strange about that board. There is NO such thing as a typical residential circuit board. (it only points out how few domestic properties you have seen). However what you need to look at is the circuit descriptions and the fuse ratings. Which all look pretty normal for any domestic property. As has been said it could do with (a) a FULL periodic inspection + condition report AND (b) upgrading to RCBO's instead of single RCD / RCCB.
