Up against a WALL !
electrics_new
Apr 23, 2013
134
Leeds
OK went to an ex council flat in leeds - re rewired the sockets as there was only one ring main in whole flat and test results indicated a fix.  Lighting  circuit tested ok (usual R1 + r2, IR etc).
Anyway cut a long story short and redone sockets into several circuits. Light pendants just wanted a change old dated, painted over a needed a change.
It's MI, Pyro cable and on the last light fitting the switch live cable - came off in my hand as soon as I touched it.
HOW THE F**&&**&&& can i fix this ?
the cable just snapped off as soon as I touched it.
What an afternoon ????
ps the copper dot on the left hand side....... is the cable that snapped off.
nasty... looks concreted in so no re-terminating that one
it may be possible to try and solder a new bit of wire to it, but even that doesnt look promising
yes that's what I though - carefully drill a 1mm hole put some 1mm wire in and solder..................
tricky but can be done.
And yes embeded in concrete - flat has concrete walls, floors and ceiling.
for the time being - i've fitted a ceiling light with MW sensor.  Not ideal but does the job.  Customer wants a on/off switch.
Wall lights run in trunking. Switch run in trunking. Spurred off ring (using the same trunking?)
flat has been plastered and decorated..............
wireless switch - any ideas ??????
Need a low cost solution to communicate with LED Micro Ware Switch light............ can change the light no issue.
thanks
sorry binky............... should have been more clear.
At the moment fitted a light with build in MW sensor.  But happy to change ???? to a light with a wireless switch !
it doesn't unles you want to be in the same room and turn the light off
wireless switch does seem your best option. I do believe cost effective options are available these days.
