I have a redundant door bell in my hall. I want to install an tablet with wall mount directly underneath it and wondered if it was okay to use the bell wire (assuming its 24VAC) to carry 24VDC which will then be converted behind the tablet using a 24VDC to 5VDC buck converter to power the USB port on the tablet.
In addition, the current bell transformer at the CU it positioned outside of the enclosure I'm assuming so as not to mix Band I and Band II electrics. Would it be okay to fit a 240VAC to 24VDC transformer in the CU and ensure that the bell wire was additionally sheathed with 240v rated insulation?
And finally, the reason for going with 24v was to ensure no voltage drop over the approximate 10m distance to the tablet. Is there a better option still using the bell wire.
Thanks.
Thanks.
