VAN TUBES
Same as PC...a length of grey waste pipe with screw end caps does for me.
30quid for waste pipe and bits.
Depending on roof rack get some 6mm threaded rod and loop it over the pipe and drill 2 holes in your roof rack with a bolt on the other side, looks like it grew there!
Buy one but it depends on what manufacturer you have to what vans they build them for. What van have you got bud?AndyGuinness
just a 04 kangoo, just used for own work
i have used a 6 inch soil pipe in the past. used a bit of wood to blank end, and an adapter with 1 end blanked as end. remove rubber o ring and its a loose fit. use some shock cord between pipe and end to keep it in place
I'v got a transporter and the 4 inch waste fits inside from the back to under the drivers seat, after a bit of bending! Not sure if it'll go in the Kango tho'
ive got a metal lockable tube, got it from wholesalers who iirc 'lost' it on a big order that a customer of mine was paying.
