currently carrying out pir on small commercial building on an industrial estate. main board is fed by 25mm 4core from a 100a bs 88 switch fuse in an outbuilding. this switch fuse is fed via a 50mm 4 core which goes off to a substation on site which we have not got acsess to and dont know how is protected or connected. problem starts here - zs at db is 0.98 ohms. zs at switch fuse is 0.97 ohms. the 50mm 4 core run is approx 25meters to substation. am i right in thinking there is something seriously wrong here? i no i havnt seen whats at the substation end yet but im thinking we have a big problem if the zs at db is so high and the switch fuse contains fuses with a max zs of 0.42. please someone tell me im not going mad and missing something.
