Hi, apologies if this is in the incorrect place, posting here as there seems to be a bit of conflicting advice regarding electrical regulations and the cai guidelines in this area when it comes to tv aerial bonding.. So I was hoping I could get a tv distribution point of view about what is correct.
As I know when it comes to having tv distribution inside a house or commercial premises each output from the splitter cai guidelines are it should be bonded to the rest. But electrical standpoint is by doing so you are bonding the tv aerial turning it into a lightening rod.
Anyway, for one moment let's assume that it is correct that everything should be bonded.
Shouldn't virgin media connections at the very least be earth bonded inside the omni box? On the wall outside so like the gas, water services it is the same potential as everything else in the house?
I know vm don't do this, but all their splitters and 12v powered hdu devices have earth terminals built in, and I think I've seen photos of Comcast cable in Germany and theirs are all earth bonded.
Just came to my attention as through the outer shielding of the cable you are connected to every other house on vm network and at times I have noticed touch voltage occasionally and also read a case recently about somebody where somebody else's house equipment developed a fault and it did some damage.
I don't know about their cabinets but around here vm use pits with splitters in them, rather than everyone going back to a cabinet.. And when I saw inside that pit the splitter is not earthed, and from the photos inside the cabinets I've seen those don't appear to be totally earth bonded. So whatever voltage gets onto the line through the outer coax shielded is fed to each customer.
DialectrIc voltage is blocked via the isolator on the wall lol but that doesn't stop the touch voltage.
