Hi, I've been asked to run a cable approx. 200 meters to run a shop metal shutter. It has a switch that has a common feed and three cables out, one is on the switch that lifts the shutter the other is off and the 3rd is lower shutter. The current is very low, I put a clamp meter on it and it read 0.06 Amp when running. The voltage is 230VAC. Will I need to worry about the length of the run? If you can advice me I would appreciate it.
Many thanks
Paul
Many thanks
Paul
