walk over/drive lights
matt.leung
Feb 26, 2009
1,062
Bromley, Kent
On saturday i am going over to give an estimate for some walk/drive over lights. I have never installed these before so i have been looking at some wholesalers etcs...
i have noticed that they come supplied with normal flex as a plug and play systems whiich i find really odd, as i would thought that swa would have to be used etc....
can i please get some advice .....
Not done any myself Matt , but I'm sure they are low voltage ,( by "low" I mean 12v)
Or they will be LEDs .
You wouldn't be able to connect SWAs to pharty little light fittings.
flex into resin joints would be your best idea tbh as the resin joints are a permantent sealed joint, i use resin joints a heck of a lot, and have never had one fail.
Depends on whats on top of it tbh. Could be a lot less if its in a concrete slab for example.
hands up badger. not done a joint like that for along time.
in the wholesalers you used to get a big bar of very similar to pyro putty.
if you bury a conduit box in the ground it will naturally have water run past it as the ground soaks with rain and the water goes down to the water table
a lid and gasket just doesn't cut it
i found this for ya tho
http://www.rainbowtech.net/products/view.php?cn=4035
