What are they called?
Dambo
Oct 7, 2009
473
With surface mounted switches the pop out bit on the top of the switch where the cable can enter is quite a bit bigger than the cable itself i.e. someone could put their finger in. What are the little rubber coverings called that can be put around the cable at the entry point to stop this happening? :eek:
Do you use the Paxo type?
Yes, just tap out the knockout, insert cable with paxo, pour boiling hot water over and your done. For swa you can drill and tap the paxo to earth it.
^^ ROTFWL
Anyway, returning to seriousness, here is an image of a Grommet.
yes it was a sort of joke, i tend to call any possible discrimination racism nowadays its just so difficult to keep up with all the different types i simply find it easier to call of them racism :)
PS. this is also a joke ;)
