Hi all,
Just canvassing opinion here.... Situation is terraced houses converted into two flats but the electrics remain as original. So I have two PIR's both flats where only one tenant [ie the downstairs one] has access to the CU.
I have have coded as 2 on the basis that there is no safe of localised means of isolation. Apart from this there is the obvious problem of a trip and the upstairs tenant will have no access to reset the trip if they can't get in downstairs.
I have told the LL he either gets the properties rewired or has the CU moved to a common access point.
What do you think?!
Dunx
What do you think?!
Dunx
