good answer:ApplaudThermogalvanic Effects Driving potentials for the corrosion of copper can be created by temperature differences in under-the-slab, hot and cold domestic water lines that are in metallic contact with each other at the hot-water heater. This phenomenon should be suspected when the external corrosion of copper water lines occurs only to the hot-water tubes.
Copper is anodic to carbon, and corrosion can be expected to occur if contain appreciable amounts of carbon. Moisture, however, must be present for this galvanic action to take place.concrete will normally be cathodic to nearby copper
Thats what I was going to say !!!Thermogalvanic Effects Driving potentials for the corrosion of copper can be created by temperature differences in under-the-slab, hot and cold domestic water lines that are in metallic contact with each other at the hot-water heater. This phenomenon should be suspected when the external corrosion of copper water lines occurs only to the hot-water tubes.
looks like he just beat you too it, mate.Thats what I was going to say !!!
upgrade the 2.5mm feeding it first ROTFWLso bang a new shower in, sorted
will just put a 20 amp mcb. :runupgrade the 2.5mm feeding it first ROTFWL i know its just the pic ray
