bulmer Senior Member Joined May 30, 2008 Messages 354 Reaction score 0 Mar 2, 2010 #1 Which type of Wago do you guys use when connecting up tranformer for spot lights? Had a look at their website, but still not really that clear as to which is best.
ianmacd Well-known member Joined Mar 15, 2009 Messages 3,877 Reaction score 0 Mar 2, 2010 #2 If its got flex then the lighting ones are best. They do 2 versions, one with one cable comming in (maybe for the last light on a radial?) and one with 2 cables comming in (maybe for the others so you can link out to the next light?). Single wire: http://www.wagobox.com/shop/lighting/lighting-connector-pushwire-to-cage-clamp-20pcs.html?SID=6etkhdgkelhdnpq0q8ruvhdu52 Twin Wire: http://www.wagobox.com/shop/lighting/lighting-connector-2-x-pushwire-to-cage-clamp-20pcs.html
