Should be easy enough to install, although the WiFi unit will need to be mounted in an enclosure, otherwise you have exposed mains terminals. You might be better off with a battery powered unit to avoid any mains work. Accuracy will depend on the clamp, but should be reasonable. They normally mount on live feed wire, which can be easier said than done.
