been asked to quote for connection of a 10kw single phase. its a hong kong effort and has a 2 core 10mm 30mtr long flex coming from it. my question to you is doest the column require earthing and would a 10mm be ok and would i take it to the MET.
I personallt think it does but not that up to date on DC and if for some bizzare reason it may effect the unit.
my 2nd question is although the flex is a tough rubber the customer is going to bury it but should it be enclosed in ducting for mechanical protection?
thanks
carl
thanks
carl
