Wire strippers - best
Patch,I dont mean to be blowing bits out of you, and all your hard work searching,
but they cant both be 8" now can they.?
make up your mind man,
which ones are 8" and which ones arent.
Ok - 8 inches = 203.2mm
One goes up one goes down!
:p
I use Stanley side cutters.
Cant be doing with faffing with "automatic" tools, which will, in due course, give up long before cutters.
I use Stanley side cutters.Cant be doing with faffing with "automatic" tools, which will, in due course, give up long before cutters.
automatic.?
am I the only one baffled by this,?
BTW, what sidecutters do you use for 35mm.?
I get the automatic bit after reading it again.......
why? what size cable do you use upto.?
it doesnt stop at 25mm, you do realise that dont you,
I would be using 35mm regularly.
I was crimping 240mm last week, and there are prob guys on here do bigger on a weekly if not daily basis.
