As i have only just worked out how to turn on this laptop i thought i would ask you lot for some ideas about a house we have just finished wiring.
Big house over 3 floors and quite wide, also loads of steel work went in so i very much doubt any wireless signal will travel.
The master telephone point is in the study in one ground floor corner of the house ( i have cabling in place that this could be extended to the 1st floor & a secondary point fitted in its place ). Thats where i would connect the router. The customer has the free router supplied by BT. We wired Cat 5 cables to a central electrical cupboard on the 1st floor (also telephone cables) from there Cat 5 cables go to the top floor & a 50m run to the detached games room. Also from the first floor cupboard Cat 5 cables are wired to the 10 Tv positions.
What would the best way to connect all this up and also give wireless access to the whole house. Would you fit a 10w hub in the 1st flr cupboard and can you extend the wireless by plugging something into the hub which is then connected direct to the router . Can more than one booster/extender be connected ?
Thanking you in advance for all the wonderful ideas you are about to offer me
