Which could also be run from your wet central heating system; Much cheaper running than an electric heater.Other option is a plinth heater, fits in kick boards under the kitchen cupboards.
Not seen wet versions, but sounds like a good idea.Which could also be run from your wet central heating system; Much cheaper running than an electric heater.
can't go wrong with more circuits, more the merrier, it means a simple fault on your ring circuit affects less things and is easier to fault find.Thanks ProDave - hoped it was something like that. Not a problem then.
Binky - thanks for the plinth heater suggestion.
The new ring circuit I'm suggesting could therefore instead feed a plinth heater of similar power to the UFH. So, again going back to the original question / scenario, does that proposed new circuit seem a sensible option? Seems fine to me, but as said before, I may be missing something.
