Evening.
I went to investigate a wiring problem on a domestic heating controller on friday. As i dont really do domestic heating controlls it has me a bit stumped.
The heating timer had apparantly failed sometime ago and the householders son had done a temporary `fix`. He now wants a clock fitting.
What i was presented with was a fused spur output connected to 3 choc block connectors and a mass of wires. When the owner wanted the heating or water on he just turned on the spur.
The previous time clock was a Potterton mini minder E and all the wires below were mounted into the connector plate, now removed.
L-N-E from Spur
L-N-E to pump
4 core flex that disappears behind back boiler.
On the rear of the timeclock there is a dial set to `Fully Pumped`.
The way it was wired into the choc block was-
L - Live to pump & Brown + Black of the 4 core cable
N - Neutral to pump & Blue of 4 core
E - Earth to pump and earth of 4 core
When householder turns on spur he gets heating and hot water.
Looking at various wiring diagrams (s/y/c plan) i cant see how its possible to wire up!
As you can tell im not up on heating system wiring.
Any help much appreciated
L-N-E from Spur
L-N-E to pump
