- Nov 28, 2009
- 14,831
- 1,005
The manual for that unit is about as much use as a chocolate tea pot.
It has 3 speeds available. You will probably only use 2 of them, the slow speed on all the time, and the faster speed when the bathrooms are i use.
So the simplest way is probably use a relay to do the switching from slow speed to full speed. Then you can activate the relay from any number of locations with for instance the timer unit that I used https://www.tlc-direct.co.uk/Products/SMTGBT4.html
