I can't make my mind up about this - would appreciate your views.
I've got a re-wire to plan with customer in residence. I don't do many....too much messing, normally, but this is a friend of a friend.
My question, simply, is this:
Those of you who do re-wires, do you remove all the old cabling or do you leave some in the fabric of the building.
The reason I ask is that a lot of this rewire is going to be routed a completely different way than it was originally - so I'm thinking 'twice the mess' if all the old cable was to be removed as well.
Is there any reason why it can't be left as it is, in plastered walls or under certain floorboards that aren't being taken up?
Obviously, the easily accessible stuff will be ripped out.
Thanks in advance.
Thanks in advance.
