Here`s the scenario:
Some wazzock installs two ground-mounted external luminaires, wired in SWA. the 2 swa feeds are taken to an IP box, mounted to the side of the building, along with the feed swa (all bottom entry).
HOWEVER - he doesn`t seal the fixing holes. When box lid unscrewed, lots of water emerges. baaaaad ****!
Because all swa cables are bottom entry, they`re full of water.
Question is:
Do you
a. discard existing swa altogether, and replace with new.
b. unearth, and cut back x distance to find clean (dry) point for cold resin connection? If so, what value is x?
c. other?
I`m tending towards a, but welcome my esteemed colleagues` feedback and viewpoints.
Thanks in advance.
KME
Question is:
Do you
c. other?
Thanks in advance.
KME
