Light fitting wires
Stevie R
Nov 19, 2024
17
5
Lancashire
Please see attached photos of a light fitting which I’m about to fit, obviously there are 3 wires connected to the light one is the earth but the other 2 aren’t identifiable as L or N they are just identical wires I’ve never had a fitting like this before so which would be L & N ?
    1.3 MB
    957 KB
What type of light is it?
A lot of the time it doesn’t matter, sometimes it does though.
Is it a new light fitting as the ends look a bit rough and with some rough solder on them.
look very closely. there usually a coloured string in there
if there isn't then unless its a ES holder then its not going to matter. if its ES then you'll have to test which is which
Probably won't matter if it is ES if manufactured to correct standards.
What do the manufacturers instructions say?
If it's second hand and has no instructions then all bets are off.
Post a picture of the actual light fittings, and if it is a replacable lamp (one or more) post a picture looking into where the lamp fits (with the lamp removed)
Looks like a bit of second-hand butchered flex to me..?
Otherwise those fine strands would have ferrule/crimp over them.
I would start by trimming the sheath and cores back a bit..
Crimp on some ferrules..
Then some continuity tests to verify not just polarity, but earth continuity to any exposed metal parts.
Plus an IR test in case the other end of the flex is as bad looking as this end, and it has some wire strands touching bits they shouldn't touch!.
It’s not second hand it was installed in our previous house weve brought it with us
That can be connected any way polarity is not important.
I disagree.
That is an SES Small Edison Screw lamp holder.
The bottom / left contact in that lamp holder touches the bottom of the lamp That should connect to L.
The top / right contact, makes contact with the metal screw thread of the lamp, that should connect to N.
This is important because if someone tries unscrewing the lamp while it is on, they might be able to touch the screw thread part of the lamp, which could be disastrous if that was connected to L
Anyone else back me up on this?
Yes it will "work" either way, but I do not believe it will be safe if connected wrong.
I disagree.
So how do I identify L@N?
That lampholder unless my eyes deceive me complies with EN 60238 so see Regulation 559.5.1.206.
You can hope it does, and trust that you can't touch the screw thread of the lamp holder, or very simply you can choose to connect it so L goes to the top cap of the lamp and N goes to the screw thread of the lamp. I know which i would do. Why take ANY risk?
This is a multi headed lamp the wires in the picture are goin to the mains supply in the ceiling
So personally I would check continuity and first confirm they are all connected the same way around.
Or take advice from others and just connected it. I seem to be a lonely voice here suggesting you try and connect an SES lamp holder the correct way round. I like to do things technically correct, but nobody else seems bothered about that.
