- Joined
- Nov 28, 2009
- Messages
- 14,851
- Reaction score
- 1,040
The whole point of a consumer unit is to provide circuit protection so no circuit can be overloaded, the protective device will trip first. Clearly that did not not happen.
Indeed faulty component or faulty assembly, but those that make the rules thought they would solve the problem by putting it in a tin box to contain a fire, rather than improving the components or assembly to prevent a fire. As I have said before.doesn't need to be overloaded or fault current to start a fire
It would be interesting to know what brand the board was. Not that it necessarily would be the equipment at fault, any loose connection could start a fire.doesn't need to be overloaded or fault current to start a fire
