1/2"socket to hex adaptor for impact driver?
I bought some from machine mart don’t know if they are specifically rated as impact but have used them for a couple of years on the vehicle with no probs?
of course there is also this ?
https://www.milwaukeepowertools.co.uk/milwaukee-48325032
Thanks mate, I know you're a millwaukee guy but all the millwaukee impact stuff I have purchased previously has been made of chocolate, quite a few reviews I have read say that this is no different.
 I appreciate that 1/4 inch hex is quite small and probably won't take much abuse but was hoping there would be something out there?
i got some cheapish ones from screwfix. mostly the 3/8 one thats used in the small impact (1/2 goes in the 1/2 drive impact). works well, does the job
Cheers Andy, I have a Makita with a 1/4 inch hex.
A 3/8" or 1/2" driver would be great but my wallet is a bit empty right now! :(
I got a set of 3 cheapish ones from screwfix,
I've used the 1/2" one to take the wheels off my van, and even loosen the hub nuts [ 46mm ] using my 18v Milwaukee impact, so they take a fair bit of abuse,
Like the one @sharpend posted.
I have lots of socket sets, almost to the point of OCD, Don't know why? I just like them I guess!   :innocent
Don't have a 1/2 inch adaptor though I do have a few 1/4 inch adaptors. :C Am doing a fair bit of heavy duty tray & ladder at the moment with my wera ratchet ( the tiny one :lol: ) and need to speed things up a bit!
@steptoe these?
https://www.screwfix.com/p/erbauer-socket-driver-set-3-pieces
My impact driver is 160Nm!!
Thanks!
I have lots of socket sets, almost to the point of OCD I don't know why? I just like them I guess :innocent Don't have a 1/2 inch adaptor though I do have a few 1/4 inch adaptors :C Am doing a fair bit of heavy duty tray & ladder at the moment with my wera ratchet ( the tiny one :lol: ) and need to speed things up a bit!
@steptoe these?
Thanks!
mine arent as shiney as those, thinking about it, they may have came from toolstation, or CPC, but, they certainly werent expensive, about a fiver iirc
tbh, if you are doing tray etc, its not as if they will get a load of abuse anyway, even if in an impact
https://www.toolstation.com/shop/p31432
I know doing the actual tray shouldn't be too much abuse on them, there is only so much a 6mm roofing bolt will take!  :slap
It's more a bout the fixings we are using, nasty plugless Fischer things.
I hammer in 10mm thunderbolts with mine on a weekly basis,
these type of things
https://www.toolstation.com/shop/p28067?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMIyqWkt-Xd2gIVCLTtCh3ETQ8-EAQYASABEgLX5_D_BwE
looking at the picture, they look like mine,
looking at the price, they look even more like mine,  :D
I've had them a few years now, maybe 3 or 4
make sure you use impact sockets,
normal sockets WILL crack after a while, even good ones
This is why I suggested the nut driver set.
Saves you buying impact sockets too.
I'lll second what Steps has said about hand duty sockets failing on impact guns, they will.
I have 2 with 1/4” hex, 10.8 & 18V, and an 18V 1/2” drive, along with a 3/8” & 1/2” air operated in the workshop, they eat hand sockets eventually, even the best that money can buy, any make.
