Seanl
Afternoon all, newb here and I have a couple of questions regarding wiring to a garden building. I've had a good search online but can't find any definitive answers or anything similar to my circumstances recently. So the background is I have 10mm SWA that I need to run to a garden building. It's approx 26m from the CU in the house, going to an IP rated sub main CU in the workshop. It's only supplying lights and a couple of sockets initially, but I want to future proof as we've been considering a hot tub for a while, so a 32a supply will give us greater options. The first question related to entering the property. The house is a period one with foot thick stone walls. The main CU is in the front room and you can see on the pic the mains in cable to the CU. Drilling through from internally to ensure I miss any other cables is obviously the wisest choice, but a 25mm hole through such a thick wall isn't my idea of fun. Coupled with the bend radius externally and the preference for neatness, would a terminal box be advisable in this situation and if so, does anyone have a link for an appropriate one? The cable would then be run along the side of the house for approx 3m at 2m height, down and underneath patio slabs on a step, then through a block wall which acts as a flower border. The second question I have is routing. The flower border runs parallel to a fence which rises up, so the only suitable route without raising the rear patio (not really an option as it's recessed so slabs will have to be broken to lift) is to run it along that border. Given that it's right next to the fence, if the posts needed to be replaced then that's the only place to dig. Being 2 -2.5 foot deep as they are, burying the cable would present more of a risk of it being damaged even with warning tape in place. I've seen previously that others have located the cable behind gravel boards. Is this something that those with experience would recommend in this situation as well? Sorry for the long post, I've tried to add photos for clarity but can't seem to attach them at the moment. Any advice would be very much appreciated. Thanks, Sean.
