it does matter, because you need to make sure the earth is the correct size for fault current to open breaker. no good assuming 6mm when its 4does it matter bigger is better ?
Was working on basis that u needed 4mm then 6mm would be okit does matter, because you need to make sure the earth is the correct size for fault current to open breaker. no good assuming 6mm when its 4
