J
Jacko29
Guest
I have come across an installation that appears to be using 10mm T&E from the meter (via isolator) to the CU (about a 6 meter run). Seperate earth conductor from MET to supply.
The first question is, is it OK to use T&E as supply cable. The CU will need changing due to damage and I am assuming I will need to update to SWA.
My feeling is, board change will require SWA cable used for supply. along with a correctly rated fused switch for that cable.
If I change the board and left cable as is, would I be in breach of the regs on this one?
Your thoughts please
