12v LED van lights
daisy
Sep 19, 2024
Inverness
Hi
I have just wired up 4 LED lights in my van. They are all linked and then positive runs to the switch which then runs to the fuse box, negative runs straight to the fuse box. When I put the fuse in, all 4 lights come on and stay on, regardless of whether the switch is on or off. When I take the fuse out, I can use the switch to turn them on and off, however when I turn them off they stay on very dimly.
Any suggestions or advice would be much appreciated 👍🏻
daisy, a car is not wired the same as a house. What you would normally do, is take a wire from a spare fuse, (This is the positive +ve) take this wire to one side of a switch.
From the other side of the switch go to the first light's +ve connection.
From here you then go to the 2nd, 3rd & 4th lights +ve terminal.
Each light now has a wire that goes +ve when the switch is turned on. The lights will NOT work as we have not yet connected the negative. (-ve) Since the car is metal, if you secured each light with a screw or two, you probably screwed into the steel work of the car. All you need do is connect the -ve of each light to the screw that is securing the light, there by you are connecting it to a permanent
-ve.
If you have not screwed each light to the steel work of the car, you will have to run another wire from each lights -ve terminal and find somewhere you can attach a screw, and connect the wire to this. Obviously do not drill through a side panel or the roof. (It will work, but you will have a leak and a hole you do not want.)
