150mm timed extractor fan not working with timer function (photos of wiring)
Vedb
Nov 25, 2024
5
London
Hello all!
I've got a peculiar issue whereby the wiring of an extractor fan seems to be wrong (but working) however it doesn't allow for the timer function to work off the permanent live. Please take a look at the photos to show you the inputs, the wires and also the only configuration which allows the fan to come on with the switch. I'm confused as to why the inputs don't match in the conventional way and also why the permanent live won't keep the fan on after switching off the light. Any advice?
Much appreciated!
That's just it, the usual colouration doesn't apply here and I don't know why it was wired this way. However the only combination which works is the one I've shown on the photo, otherwise the fan doesn't power on.
You can see what they're labeled as on the fan so the assumption is that the wires then correspond to these with black being live, brown timer and grey neutral. I've tried them every which way to see if I can get it right but it always comes back to this.
